PMWICON's avatar
PMWICON
Tutor
Dec 31, 2019
Orbi creating two different IP Ranges?
Hi All,
I am hoping someone can help me.  It seems I have two different IP ranges floating around my house.  First, a bit about my setup...  I have a Netgear ORBI RBR50 with one satelite.  I also have a CUJO Internet Firewall.  Orbi is set to use my ISP to dynamically set the IP address of my devices.
Now the issue...  When I look at my "attached devices" in orbi I can see them all just fine.  The issue I have is that there are two different IP ranges that are showing up.  I have the standard 192.168.x.x that Orbi is using, but I also have a 10.0.0.x range.  The issue I am having is that when I try to control certain devices with my phone they cannot be found because the phone views them on a different network.  Examples of devices I am having issue controlling are Sonos speakers and Apple TV 4k's.
Any thoughts on why this would be happening?  Does the orbi satelite use a different IP range than the main orbi hub?  Is it possible I have an old network still floating around my house?  I am really getting frustrated, and I am not sure where else to turn.
    • PMWICON's avatar
      PMWICON
      Tutor
      I have an AT&T moden/wifi router combo.  All WIFI capabilities are disabled on the router.  I spoke with AT&T for about an hour this morning and we did a bunch of torubleshooting, but the only IP's they see being set on their side are the 192.168.0.x ranges.
