wallerce
Nov 08, 2017Follower
Orbi dropping connection using external VPN connections
I have had my RBK50 system since July of this year and the Router and Satellite both have firmware (2.0.0.72) and overall the system and performance have been great. When myself or my wife are using ...
Maytag21
Dec 22, 2017Initiate
wallerce
I posted earlier this morning and was hoping to get some feedback to see if my VPN issue solution works for anybody else. At first my wife was getting logged off of her work VPN 2-3 times per hour. Currently she's now been logged into her work VPN (Cisco) over 4.5hrs straight with zero drop offs.
https://community.netgear.com/t5/Orbi/Orbi-Dropping-VPN-Connection/td-p/1183702
- loutzlFeb 12, 2018Aspirant
Did you get a response for this or ever fix it. I ran into same problem this week. Thanks
- guzzijasonFeb 12, 2018Apprentice
I use Juniper rather than Cisco VPN, but I've had no issues.
If you are in router mode, and you are connected to another router, then you could have issues with double-NAT.
