Abeheary's avatar
Abeheary
Orbi dropping internet connection when ethernets connected
Suddenly my orbi dropped connection, I had to reset it as nothing works. Upon reset it’s working but each time I connect any Ethernet cable to it, it disconnects. Please help. It was fine for the past 6 month.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello abeheary
    Are all of your orbi units on the same firmware? also have you tried another ethernet cord in all the ports?
    DarrenM
    • Abeheary's avatar
      Abeheary
      Yes all on the the new firmware. Ethernet not functioning on the main device. Once I connect them it disconnects an turns magneta. And now even wireless keeps on disconnecting. I restarted my orbi and the je main router but still.
      • RocketSquirrel's avatar
        RocketSquirrel
        Luminary
        I think the Orbi hardware is pretty solid. And I wince a little when someone says “I’m on the latest firmware” without specifying the version number. Both 2.0 and 2.1 may be considered the latest version because 2.1 was withdrawn. And 2.2 is on the horizon.
        2.0 - wired backhaul kills your whole network; wireless backhaul works
        2.1 - wired backhaul works; reportedly suffers from connection drops
        2.2 - works well but isn’t finished, still in pre-release, can be obtained by asking Support
        I’m running 2.2.0 and it’s unfinished but rock solid.
