Anonymous
Oct 06, 2017Orbi dropping wireless connections
Hi,
I'm having problems with wireless clients being disconnected. It works for awhile and then the client is disconnected, and then it reconnects and disconnects and this goes on for awhile and then seems to work for awhile before it starts happening again.
There isn't much in the log, all I can see is a bunch of DHCP messages assigning an ip address. For one device I saw 160+ requests over a 3 hour period.
I'm running the latest firmware 2.0.0.74.
Glen
- DarrenMSr. NETGEAR Moderator
Hello kiwiglen
Do you have beamforming and mumimo enabled in the advanced wireless settings?
DarrenM
- Anonymous
Darren
Those are all turned off.
I've had the Satellite turned off for the last few days and its been rock solid, I've just turned it back on today to see if that is causing the problem.
I also tried to raise a support ticket for the issue but I couldn't (no error message or anything) it just wouldn't create it. I think the issue is that I have managed to register the product twice, are you able top delete one of the registations?
Glen
- Anonymous
So the Satellite has been going for a few hours now and I'm back to getting dropped devices. It looks like it always devices attached to the satellite that drop off.
Is the Satellite faulty?
Glen
- OrbiDemigodApprentice
I have this exact same issue the past few months, connections dropping like wild fire. First 5 months were great, no issues ever.
Can we please getting a FN fix?
