JayMan7
Jan 14, 2019Initiate
Orbi Ethernet Backhaul showing connected as 5G
Just purchased the RBK23; set-up as AP mode with FiOS. WiFi is working, and have the Satellites connected via GigEthernet, but they are showing connected with 5G on the web interface. Also, devices connected to the Satellites, are showing to be connected as "wired" and connected to the Orbi-Router, and not to the Orbi-Satellites.
For what its worth, on the iOS App, neither Sat is showing as a Satellite, just as a connected device.
Both are identified in the diagram, and both have the magenta "dot".
Anyone else having this issue?
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.Try disabling the following and see:
Daisy Chain, Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
For wired back haul:
Set up IP address reservations for each satellite and devices on the router as you add them to the router. The satellites need to be set up via wireless first. Then connect 1 satellite at a time to the ethernet LAN cable. Wait 5 minutes and the top led on the satellite should turn on BLUE. Set up an IP address reservation for the 1st satellite. Continue to do the same thing for the 2nd satellite. Then follow up with your devices.- JayMan7Initiate
Messing around with this some more this afternoon, I moved the connection on the Orbi router from Internet to LAN, and now the web GUI shows how and where and how each wireless device is connected, as well as both Sats showing as wired. The ios app also shows the satellites connected as wired.
However, after moving to the LAN port, the ios app would show no internet connection, and the router itself had the magenta light on.
As a test, I changed the wiring so everything goes through the Orbi Router, the magenta light went out, and the app shows internet connection.
[FiOS_Router] <-> [WAN/Orbi Router/LAN] <-> [Switch] <-> [Orbi Sat]
I had previously specified an IP address for the Orbi-Router, but have not seen where to perform this for the Satellites. Where is that configured?
Thanks,
JayMan
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopIf your using the FIOS router then you would specify IP addresses here for the Orbi router and satellites in AP mode. If your using the Orbi router in router mode, then you specify IP addresses for the satellite(s) on the Orbi router under Advanced Tab/LAN Setup.
I recommend you try option #2 with your Orbi system since you have a router in front of the Orbi router.
Thanks,
JayMan
- ekhalilMaster
It seems that your satellites are not correctly synced with the router. Please use a paperclip to reset your satellites as follows:
- Make sure your Orbi device is powered on.
- Using a paper clip or similar object, press and hold the Reset button until the Power LED on your Orbi device blinks amber. Note: If you're resetting a wall plug satellite, the ring LED blinks amber. Your Orbi device is reset.
Then sync them again by pressing the sync button on the router and satellites, one by one.
