Prismatic
Aug 14, 2017Aspirant
Orbi ethernet speed significantly slower than wifi
My wifi is working great. I pay for 100 mbps download and get at least that through the Orbi wifi. However, when I plug a laptop directly into the ethernet ports it's a whole different story. I ge...
tucsontico
Aug 14, 2017Virtuoso
Not to seem pedantic, but have you checked the ethernet cable? It is possible you have a bad cable or an older cable (Cat 3). Try another cable with same computer. It is obvious you WiFi connection is giving you better SpeedTest results so I would be very suspect of the ethernet cable in the hard-wired scenario.
