argold
Jan 28, 2019Guide
Orbi Feature Request
I just noticed ths forum and apologise if I'm asking for something already discussed. If so, please point me to any existing thread or comments.
I would like more flexibility with the wireless ...
Jan 28, 2019Guru - Experienced User
The main issue isn't Orbi and the smart connect, it's how the IoT Mfr setup software is handling howe the setup mobile device when it's connected to 5Ghz rather then 2.4Ghz. 2.4Ghz devices will ONLY see and use 2.4ghz. They can not connect to 5Ghz ever. For some reason IoT mfrs are not allowing thre setup apps that are run on 2.4 AND 5Ghz supporting mobile devices to work on 5ghz during there setup process. Mfrs needs to allow the users mobile devices to connect to either frequency during the setup process regardless if there IoT device only supports 2.4Ghz.
If you can get your mobile device to connect to 2.4Ghz long enough to setup the IoT device, it should work. You can try and turn down the 5Ghz power power output temporarily to see if this helps your mobile device to connect to 2.4Ghz.
- argoldJan 28, 2019Guide
Whatever anyone claims is "the main issue" the problem would be solved of Orbi allowed the two wireless bands to be separately controlled through the web interface.
The hooks are all there in Orbi's code and they can be accessed using telnet to busybox using config set wl_ssid="SSID" for 2GHz and config set wla_ssid="SSID" for 5GHz but that's a real PITA.
I've never met a device before that nailed the two WiFi bands together and I don't like it. Please, Mr. Netgear, fix this.
- FURRYe38Jan 28, 2019Guru - Experienced User
The main issue is that the IoT Mfrs needs to allow there setup software and setup devices to be connected to either radio while it setup up the IoT device. Techincally 2.4 and 5Ghz are on the same network thus can communicate between them. The IoT Mfrs are not testing this for MESH routers that use Smart Connect. Would be easier if IoT mfrs step up to the plate and do there development to make things better for there products when connected to MESH routers using a single SSID name platform.
You can make a request here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Good Luck.
- CrimpOnJan 28, 2019Guru - Experienced User
The original question asked if there were existing threads about how to connect IoT devices which have only 2.4G radios to Orbi. Yes, there must be over a dozen. (I'd first search for "2.4G".) A quick Google search turned up similar threads regarding the Google mesh WiFi, which has the same behavior as Orbi (both 2.4G and 5G share the same SSID.) As Furry pointed out, once the device learns the SSID and password of the Orbi network, it will connect at 2.4G because that is the only network that it can access. The issue appears to be that some manufacturers have crummy smartphone apps that tell the device what SSID and password to use. Having the device set up a temporary WiFi of its own and using Bluetooth both work great. What these bozos are doing is a mystery.
Smart plugs were mentioned. I purchased smart plugs from Aukey, Belkin, and TP-Link. My smartphone was connect to Orbi at 5G. All three brands configured successfully and connected to Orbi successfully. I did NOTHING to Orbi to make this happen.
So, how to handle the devices made by incompetent manufacturers. (1) Get rid of Orbi and purchase a mesh system made by somebody who allows different SSID's for 2.4G and 5G. (2) Use one of the "telnet tricks" to temporarily disable the Orbi 5G (change the SSID or lower the power to nothing). (3) Find out if other users have found a way to get that specific device to work on a mesh network. (4) Dump this product and purchase one that works. (If they messed up connecting it to WiFi, what else have they screwed up?)
Your pain and frustration are very real. You can ask Netgear to modify the product, but I would not hold my breath.
