bhenry's avatar
bhenry
Tutor
Jun 16, 2020
Orbi Firmware page shows 2.5.1.16 for router BUT says waiting for connection for Satellites
The downloads page for both my Router and Satellites show the 2.5.1.16 firmware is available.  On the web UI though the orbi just shows a firmware update for the router to 2.5.1.16.  IT shows nothing available as firmware on the satellites - says waiting for connection.  In the manual update settings it shows no check box next to the satellites.
    • bhenry's avatar
      bhenry
      Tutor
      So I got one to manually update.  The other keeps giving an error with the password, same admin password as worked on the router and worked on the other satellite.
      I verified the satellite that I manually update is at the 2.5.1.16 firmware but the firmware page in the Orbi page still shows the satellite at 2.5.1.8.
      The way the orbi handles these things seems very disorganized and unstructured.  How do they not accurarelty report the firmware.
      • FURRYe38's avatar
        Be sure to use the RBS web page and load the v16 FW file directly using the RBS web page. Connect a wired PC to the back of the RBS.
