tuna_ertemalp's avatar
Jul 12, 2019
Orbi firmware update 2.3.5.30 required me to unplug/replug all my GS108Tv3 switches
This one was weird... I used the auto UpdateAll feature on the Orbi web management page to update my RBR50v2 router to the latest firmware 2.3.5.30, after a while all finished and seemed fine. Then I realized that instead of 25 devices, there were about 10-15 on my network. Wut? So, I look at what is missing, and notice all my newly installed managed GS108Tv3 switches, and all the devices connected to them, are missing. I literally had to walk around the house and unplug/replug all of them to powercycle. Then things went back to normal.
Except.... My WIRED speed on my PCs went down. Way down. Wut? After some headscratching....
I had forgotten to unplug/replug one GS108Tv3 that was connected to the LAN output of my RBR50v2, whose job was to feed a 24-port home network distribution switch which then fed wired ethernet to all the rooms, which all my three satellite RBS50v2 are connected to for wired backhaul. Since that ONE and FIRST GS108Tv3 right out of the RBR50v2 actually was offline, it wasn't feeding the 24-port distribution switch, which meant the wired satellites weren't getting anything on the wire, which included the satellite closest to the router, which then connected to the router wirelessly, and started pumping a signal back INTO the wall from which it wasn't getting any signal as it was supposed to, essentially became a producer instead of consumer of the ethernet signal, which then ended up feeding the 24-port through the port that was feeding that wall jack, which then ended up feeding the whole house through the other ports of the 24-port. Therefore the remaining satellites were "wired" as well as everything else in the house, but all the traffic was going through that wireless connection between the router and the one satellite.
I guess this is the beauty of the selfhealing nature of the TCP/IP networks. Designed to withstand a nuclear war, and therefore can withstand one missing switch, if it can.
Still, though. All my GS108Tv3 deciding to stay inactive at their incoming port after the Orbi update's completion is disconcerting. I will crosspost this to the Managed Switch forum, too, since I can't tell if GS108Tv3 has a problem recognizing the live signal coming from a re-firmwared Orbi RBR50v2 or whether RBR50v2 is not sending something out that it should to "wake up" any managed switches on the network after getting re-firmwared for them to start listening to the incoming signal port. Blanca_O
Tuna
    • schumaku's avatar
      schumaku
      While the GS108Tv3 is not a managed switch (it's just a Smart Managed Pro model): Like every Ethernet device, when an Ethernet cable is plugged or the interface on the other device (here: Orbi) is enabled, we can expect that the Ethernet link is negotiated and established. No magic wake-up signalling or whatever.
      ChristineT please ensure the newer switch models are all added to the community model selection, thank you!
      • tuna_ertemalp's avatar
        tuna_ertemalp
        Luminary
        Exactly! Everything should have just worked. However, after my one RBRv2 router + three RBSv2 wired-backhaul satellites finished auto-updating, incoming ports (in my case Port 8, since that is what I use as a self-imposed standard) on all four of my GS108Tv3 were dark. Unplug/replug of the Ethernet cable on those Port 8 did NOT help. Only unplug/replug of the power cord to the switch did.
        Tuna
  • FURRYe38's avatar
    It's the switches your using are problably causing your Orbis bad behavior. Smarts swithces are still known as managed switches. Any IGMP and Green Ethernet features on these switches are not compatible with Orbi.
    I use HP and D-Link non managed, non green ethernet switches, don't see any issues with power and recovery while my RBS is wired.
