BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Jul 14, 2018Guru - Experienced User
I've setup my friends 50 series system for him, ROUTER mode, and has had no complaints about it. I keep asking him how things are going. Says no issues.
If you feel your system is not working well, you might ask for an RMA.
JMU1998
Jul 14, 2018Luminary
cheshbr Thanks for the tip about the NetAnalyzer app I will definitely give it a try next week. As to downloading Firmware separately I have done that. Also factory reset sattalite and main unit, nvram wipe on both, manually re-entered configuration settings, many reboots etc... I have a googlefiberbox acting as the router with wifi disabled. Orbi in AP mode, all my devices in my network have hard coded IPs entered into router already. 1GB down/up connection, no managed switches. Still the same issue persists for last several firmwares that I have alluded to in past/previous posts.
