BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
SDplinker
Jul 17, 2018Guide
RBK23 only has 2 ports per device so there's no way to plug direct. RBK23 is fairly new I think (model is not in drop-down in the forums) - hoping for the best. It's a drag when my router is up on a cabinet upstairs and the satellites are dispersed - lots of trudging up and down. :-)
Jul 17, 2018Guru - Experienced User
You can add a non managed swtich to the back of the router if you need additional LAN ports. Besure its a NON managed switch.
These work for me:
And use good quality LAN cable. CAT6 is recommended...
Review this:
