BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Aug 28, 2018Guru - Experienced User
While it maybe recommended for some to use other Mfr routers, for others the Orbi router does work for them. I even set on up for my friend , Months ago, Router mode and it's been working just fine and he's happy, using current version of FW:
However I do agree, there are odd ball issues which I hope NG will improve upon and I beleive in the new beta, this maybe seen. I believe there are DHCP server issues along with wired managed switch compatibility issues that NG has been made aware of in there beta forums. So NG is aware and with the new beta thats available, hopefully NG has taken the problems to heart and fixed them. Hopefully users will post about it and let us all know how the new beta works. Yes, I agree, the Orbi should work well out of the box with out having to do alot of adjusting to make things work.
