BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Aug 28, 2018Guru - Experienced User
While it maybe recommended for some to use other Mfr routers, for others the Orbi router does work for them. I even set on up for my friend , Months ago, Router mode and it's been working just fine and he's happy, using current version of FW:
However I do agree, there are odd ball issues which I hope NG will improve upon and I beleive in the new beta, this maybe seen. I believe there are DHCP server issues along with wired managed switch compatibility issues that NG has been made aware of in there beta forums. So NG is aware and with the new beta thats available, hopefully NG has taken the problems to heart and fixed them. Hopefully users will post about it and let us all know how the new beta works. Yes, I agree, the Orbi should work well out of the box with out having to do alot of adjusting to make things work.
cheshbr
Aug 29, 2018Apprentice
Folks. Today I returned my Orbi RBK50 for a refund, and replaced it with Ubiquiti. I already had an Edgerouter X, and today I added a single Unifi ceiling mounted access point.
After championing Orbi for around 4 monthsbecause my system was stable, why am I pulling the plug? One of the reasons I had stability was the hours I put into keeping it on track. Lifx and HomeKit needed the most support. Mostly the issues involved attached devices migrating randomly between the router and the satellite, but two issues raised my ire the most. The new beta firmware gave what appeared to be more accurate signal strength and link rates, or it could have been a bug weakening the sat, so I asked through the forum as a beta tester about the lack of release notes about this and other issues. But Netgear did not respond, so that’s a black mark. The other issue is the 90 day support, then you pay. In Australia, our consumer laws give us 12 months warranty, so we don’t have to pay after 90 days. I was advised that poor support is grounds for seeking a refund, too, so I did.
Bye. It’s been fun
- FURRYe38Aug 29, 2018Guru - Experienced User
Good Luck.
Bye. It’s been fun
- cyberprashantSep 01, 2018Luminary
So I recently tried a 4 pack Google - wifi system from costco. Even with wired ethernet the actual wifi speeds are terrible when tested with an Iphone 6s vs. Wireless ORBI
ORBI: (wireless) - 3 sat + router = ~300 mbp/s
Google: (wired) - 3 sat + router = ~200 mbp/s
Conclusion - even though the wired backhaul for orbi is still a little glitchy, the wireless backhaul range with its 5ghz bands is insane crazy and can perform similar to wired even with the satellites spread far apart (50-100ft apart!). I still recommend ORBI to my friends and I was not impressed with google wifi (except for the price).
