JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
ratickle
Dec 19, 2017Apprentice
Installed the v2.1.1.16 firmware this morning because the release notes said it would solve the problem of the satellite NOT listing the attached devices. Not only did this new firmware NOT fix the satellite problem, it seem to have effected the stabilty of my router. My router has rebooted itself twice in the span of four hours. However, in the interest of full disclosure, I did NOT do a factory reset on either the router or the satellite after I installed the v2.1.1.16 firmware. I did do a fresh reboot though.
I've actually gone back to v2.0.0.74 firmware to try and get my network stable again.
Anonymous
Dec 19, 2017Amazing....at this rate I may never update my firmware. I'm still on 2.074 Did a second reboot in 3 weeks tonight. Total network down.
Other than that the system seem stable. Doing what I need.
- AnonymousDec 19, 2017
Is there a proper way to perform a firmware update? Some manufacturers recommend a complete reset to factory default then do the update. What does Netgear recommend?
- GleneeDec 19, 2017Apprentice
I don't know if this is the proper way, but it is the way I do it with Orbi. I only do manual updates. This means you have to download the frimware update image from Orbi website first. Check to make sure you have both the one for the router and the satellite and they are the correct one you want. I update the Satellite first. I then update the Router. I then check to make sure all firmware is showing correctly on each unit VIA my Orbi information page. I then unplug Modem, Router, and satellite. I also unhook cable input from modem. I then hook cable back to modem and plug it in. I then plug in the router and then the satellite. The wait for lights to go out.
Check to see if all is good on test.
- ratickleDec 19, 2017Apprentice
All these firmware problems might be excusable if Netgear was a newby, but Netgear has been making routers for decades. I've been using Netgear routers for decades and I never had a problem with firmware updates causing issues. This release of v2.1.1.16 firmware looks like a classic case of insufficient testing. Sure when you first install the firmware everything looks fine, but three hours later, all the attached devices have dissappeared from the satellite and the router has rebooted itself twice. Someone at Netgear seems to have dropped the ball and it is NOT giving me a good feeling about this product.
If the Netgear software engineers did their job correctly, there wouldn't have to be a magic sequence of updating the satellites before the router, or doing a factor reset or not, or doing a resync or not. Unless Netgear fixes these firmware issues, word is going to get out that Orbi is NOT a very good router system after all.
I checked with Amazon and I have until the end of January to return my Orbi RBK50. If the next firmware release doesn't fix the stability and functional problems, I going to send this puppy back to Amazon for a refund. If ASUS every brings a mesh wifi system to market, you can bet that it will be rock stable, it will function as advertised, and it will have all the features that you wish Orbi had.
- Bing-StrollerDec 19, 2017LuminaryAsus = AiMesh
I already have a AC86U in my setup so am currently exploring the options.
Suffice to say it looks impressive.
- armoredsaintDec 20, 2017Apprentice
For once it actually worked like it was supposed to, the FW update was quick and didn't stall out like previous versions. Now my sats show up on my iPhone app, and all this time useless Netgear support told me it was my fault and wanted me to reboot everything.
- ratickleDec 20, 2017Apprentice
armoredsaint wrote:For once it actually worked like it was supposed to, the FW update was quick and didn't stall out like previous versions. Now my sats show up on my iPhone app, and all this time useless Netgear support told me it was my fault and wanted me to reboot everything.
I assume your comment means that you have installed v2.1.1.16 firmware and everything is working well. Do you still feel that way after a few hours have passed?
Many of us are trying to figure out why some people are having problems with the upgrade and why some are not. Could you tell us what version of firmware you upgraded from?
For example, did you go directly from v2.0.0.74 to v2.1.1.16? Did you do a factory reset before the upgrade? Was it a manual update or did Orbi do it automatically?
Thanks in advance.
