JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
aaz
Dec 21, 2017Virtuoso
howiedub wrote:
I bought mine from Costco as well earlier this year. The 7,500sf number is on their website. You can see the 6,000sf number on the screenshot from Slick Deals. When did you buy yours? And how many devices do you have connected? I have anywhere from 26 to over 30 devices connected.
I got it a little more than 3 months ago when I visited Oregon. Came with 1.x firmware and I did a manual update as it refused to update automatically. Been doing manual updates ever since come to think of it since it's never found any firmware automatically for me - though I am in Vancouver Canada.
Right now it's listing 25 devices and two satellites connected. It bounces up to more than 40 devices when some other things are connected and some family visits.
I've always run it as the router, not an AP.
Stability has been rock solid except for the initial incident that prompted me to turn off UPNP. 1 day and 3 hours uptime now on 2.1.1.16 and all is good.
ratickle
Dec 21, 2017Apprentice
aaz wrote:
howiedub wrote:
I bought mine from Costco as well earlier this year. The 7,500sf number is on their website. You can see the 6,000sf number on the screenshot from Slick Deals. When did you buy yours? And how many devices do you have connected? I have anywhere from 26 to over 30 devices connected.I got it a little more than 3 months ago when I visited Oregon. Came with 1.x firmware and I did a manual update as it refused to update automatically. Been doing manual updates ever since come to think of it since it's never found any firmware automatically for me - though I am in Vancouver Canada.
What version of the firmware were you running right before you updated to v2.1.1.16? I'm asking because I have a theory that v2.1.1.12 caused all the problems and going from v2.1.1.12 to v2.1.1.16 without doing a factory reset does NOT eliminate the problems introduced by v2.1.1.12?
- godspeedDec 21, 2017Apprentice
After all i did last night (NVRAM reset, factory reset, and not changing much of initial re-configuration), i woke up this morning to see that both my router and satellite had rebooted (at the same time; their system uptimes were just a few seconds different). Its strange that both rebooted, i thought maybe a power surge, but the router is on a UPS (satellite is not).
Based on another user's stable configuration post, i modified my config to disable daisy-chaining (i only have 1 satellite), as well as disable WMM for both 5 and 2.4 ghz. Since i have an Asus router doing routing responsiblities (and QOS), i am guessing i don't need the overhead of Netgears QOS.
Will keep monitoring
- RogerSCDec 21, 2017Virtuoso
godspeed wrote:After all i did last night (NVRAM reset, factory reset, and not changing much of initial re-configuration), i woke up this morning to see that both my router and satellite had rebooted (at the same time; their system uptimes were just a few seconds different). Its strange that both rebooted, i thought maybe a power surge, but the router is on a UPS (satellite is not).
If you disable WMM your Orbi's speed will be limited to legacy wireless-g speed (54Mbps). This may not be an issue for you, I hope not, but you should always have WMM enabled on both bands if you want to have wireless-n speeds on 2.4GHz. and wireless-AC speeds on 5GHz.
- aazDec 22, 2017Virtuoso
Definitely not that - I updated to 2.1.1.12 and you will see all my complaints on the forum about the issues introduced. I went from that to 2.1.1.16 without wiping, reseting or anything special. Though I did reboot again after the update to 2.1.1.16 because initially when it came up it took a long time to connect the satellites - the second time it did not so I just figured that was an anomally that isn't showing again.
I can list my config if you want to know. Maybe we'll discover some differences and hopefully one of those is the cause - otherwise it's something buried in their config but not visible to the user.
