JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
jmschnur923
Dec 23, 2017Luminary
3 days 15 hours on.
31 devices
no device listing on Sats.
improper listing on router.
good connections to internet.
AP using fios.
WIFI seed 85 throughout the house 1 ms jitter.
daisy chained. Load on last Sat 35%, Transfer sat 17%. Router 8%.
mossywell
Dec 23, 2017Star
I rolled back to 2.0.0.74 in the end. Had to do a nvram clear and factory reset and set everything up again, but at least everything now works again.
Note to self: don't update until Netgear have actually tested their firmware (or left it to their customers to do for free).
- ratickleDec 23, 2017Apprentice
Note to self: don't update until Netgear have actually tested their firmware (or left it to their customers to do for free).Unfortunately, unless you have used Telnet to turn off auto-updates, within 24 hours your system will probably be pushed back to 2.1.1.16. Let us know if that happens.
- jmschnur923Dec 23, 2017Luminary
How do you do a nvram clear?
does that happen automatically with a reset?
- mossywellDec 23, 2017StarOh OK. I thought that manual firmware updates disabled automatic firmware updates?
- mossywellDec 23, 2017StarNot at home ATM but it's something like
Enable telnet
nvram clear
nvram commit
Or something like that IIRC
Oddly it doesn't do what a factory reset does (which may mean I didn't do it right myself!) No idea if a factory reset does a nvram clear (ie the opposite way round) though. Can't harm to do both when the latest firmware is so screwed!
