JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
orbirick
Dec 23, 2017Apprentice
I setup the Orbi router and 2 satellites which came with firmware 1.12.0.18. Powered them up, pulled the cable from my router that went to my PC and connected my PC to the Orbi system (local LAN, no internet connection). I set it up, then tried to manually update the firmware on the satellites from the v2.1.1.16 zip files (unzipped, pointed to the disc image file for the update), but got a message that the file was incorrect.
I've just re-connected my PC to the 'net and got fresh copies of the 2.1.1.16 router and satellite firmware and will try to manually install it again after I post this message. Not exactly a glorius start here.
orbirick
No joy with the fresh copy of RBS50 v2.1.1.16 firmware. Now how hard can this be?
- orbirickDec 23, 2017Apprentice
I suppose my other option is to connect to the 'net and try to upgrade the firmware OTA.
- mastervisa30Dec 23, 2017LuminaryWhy netgear cant we get that options to turn off and on auto uppdate,its gonna be easy to downgrade to older firmware in the future,when there is a new firmware who has many bugs,we can turn off uppdate and get older version?options to turn off auto uppdate,if netgear get this options im not sending my system back:)if there is buggy firmware version we can turn of uppdates
