JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
st_shaw
Dec 24, 2017Master
aaz, tkshaffer If you wire one, and only one, Sonos device into your network, Sonos will create its own mesh network (Sonosnet) on 2.4 GHz. You need to set Sonos to use channel 11 and Orbi to use channel 11, or vice versa, to avoid interference. That's how I have mine setup and it works perfectly. If you wire more than one Sonos device you can create network loops and crash your network.
Alternatively, you can setup Sonos to connect to your WiFi, but if you do that you must not connect any Sonos devices with a wire. As soon as you connect one Sonos device the entire system will revert to Sonosnet.
tkshaffer
Dec 24, 2017Guide
Thanks for the feedback! So you set both to channel 11? It is weird because it has been working fine for 7 months with one wired and the Sonos mesh and I let it auto assign channels.
- johnmharteDec 24, 2017Aspirant
I'm new the the orbi but i can say after 3 weeks of ownership I'm having to reboot my main device every 24hrs after v2.1.1.16
Before that, I didn't have a single issue with the two devices in my home.
Also what I'm seeing is the device keeps clearing out the DNS entries for my internet conection.
I use OpenDNS server but each time I'm forced to reboot, it goes back to Google and another DNS host that I don't recongize.
Domain Name Server8.8.8.8
8.8.4.4
209.55.27.13That loss of my my custom DNS settings definately looks to be a bug much less the loosing of connectiivty every 24hrs.
That "loss" is the purple LED on top of the main router and the cable modem is still going just fine. I can restart the modem and it will show good but the Orbi router stays purple... until I force it to restart. And... I loose my DNS settings as above. Very odd.
I don't see an easy way to fail back to the pervious firmware without a manual update...
Hardware Version RBR50
Firmware Version V2.1.1.16
GUI Language Version V1.0.0.309
Operation Mode Router
