JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
orbirick
Dec 31, 2017Apprentice
While looking at my connections to answer a question above, I decided to pull the cable running from the RBR50 to my PC, and run the cable from the office Gb switch to the PC. Somehow in the process, I managed to dislodge the patch cable running from the RBR50 to the Gb switch which obviously killed my interenet.
No big deal, I simply replugged the patch cable back into the switch, and for good measure, decided that 7 days up time was good enough and rebooted the router.
Before I rebooted the router, I noticed a slight change in the Show statistics page. Earlier looks at this page showed LAN 1 and LAN3 up, but LAN2 down. After the cable mishap, I noticed LAN1 and LA2 were down. The reboot didn't change anything.
What exactly does LAN1, LAN2, and LAN3 indicate? Is that the wireless backhaul LAN?
For good measure, I hit resync on the router, then hit the resync buttons on both satellites within 2 minutes. The top lights appeared to cycle normally and are now back off.
What does this tell me?
orbirick
Here's the stats screen from 3 days ago showing LAN1 up.
