JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
Shotround
Jan 01, 2018Apprentice
About 11 hours ago, I reloaded 2.1.1.16. This time I used 'address reservation" for family sanity devices (tv, iPad, iPhone) and various iot devices and the satellites. The addresses used was below the unassigned DHCP range. since then, I haven't observed the satellites dropping off or doing the x.x.x.150 thing. Watched two Netflix movies and some YouTube videos with no issues. No disconnects with iPhone/iPad gaming. No kid telling me how the wifi is glitchy.
I didnt reserve addresses for the laptops and desktops. Those lost connection with a few saying IP address conflicts.
Its a roundabout way to say I suspect the dhcp server. I'll probably sing a different tune when the kid gets out of school in the afternoon.
masonworld
Jan 02, 2018Apprentice
Shotround -- I also suspect the DHCP server. I was able to observe my AppleTV successfully connect to WiFi but then fail to obtain an IP address. The Apple device defaulted to the fake private IP they use after a timeout. So clearly, something prevented the DHCP server from issuing an address to the AppleTV.
I may try to reserve some addresses as well (although I am not touching anything for the moment as things seem to have calmed down). In response to the Orbi WiFi freaking out I immediately "wired" everything that was close to a hub. Now most of my high bandwidth stuff like media devices is off WiFI -- and that seems to be helping.
- ShotroundJan 03, 2018Apprentice
yesterday morning, 18 hours after I did the address reservation, communication between one of the satellites and router was out. I had a tv wired to the satellite. The kid's iPad was probably connected same satellite. I reset both as family wanted their morning internet fix.
Its about 27 hours since. Family hasn't complained. I did notice some lag time spikes up to 500ms with iPhone gaming (world of tanks), but no disconnect.
The other satellite is going strong. I haven't touched it since the other day, after flash to 2.1.1.16. It has nas and my computer wired to it.
I have 5ghz at 50% and 2.4ghz at 25%.
- masonworldJan 03, 2018ApprenticeWhy 50%? I think you said 25% was because you have no 2.4GHz devices, right? But why turn down the 5GHz?
- JMU1998Jan 03, 2018Luminary
masonworld everyone scenario, environment, needs are unique, there is no exact % just have to adjust and tweak for what works best for you. if you live in apartment and everyone is setting radio to 100% there will be massive interference so cut radio strength same for close townhouses etc... Keep you network wifi to the areas you need coverage not at max to reach 3 houses down the street or couple of floors each direction in apartments.
