JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
orbirick
Jan 03, 2018Apprentice
First time doing the telnet thing so I downloaded PuTTY for my Win 10 PC. According to the instructions here:
https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421/page/5
I should be seeing a different auto_upgrade flag. Instead of a '1', I see a '0', the one it should be changed to, per the instructions.
The auto_check_for_upgrade=1 shows the same as the instructions, so I'll change that. Other than that 1 change, is there anything else that needs to be done to stop the auto upgrades that are pushed out?
Edit: now that I think about it, it appears the auto upgrade feature is now disabled by default; the system only checks for an upgrade, but won't automatically perform the upgrade.
If that's true, then I'm going to leave the settings alone as I would like to be informed of an upgrade, but only do the upgrade when I choose to do so. Do I understand this correctly?
Edit: this is for one of the satellites. I'll check the router itself and post separately.
orbirick
Following the instructions from the above linked thread, I easily brought up the router config page.. which looked a lot more like the instructions! I made changes to only 2 of the command lines. The first one (orbi_auto_upgrade=x) already had a number greater than 1, so I left it alone instead of changing it to zero.
So now I expect to be notified of an upgrade, but only do a manual upgrade at my leisure instead of having the update done for me.
RBR50 telnet info
