JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
orbirick
Jan 03, 2018Apprentice
Following the instructions from the above linked thread, I easily brought up the router config page.. which looked a lot more like the instructions! I made changes to only 2 of the command lines. The first one (orbi_auto_upgrade=x) already had a number greater than 1, so I left it alone instead of changing it to zero.
So now I expect to be notified of an upgrade, but only do a manual upgrade at my leisure instead of having the update done for me.
RBR50 telnet info
- orbirickJan 03, 2018ApprenticeI'd be happy to look if I knew what to look for.
- tagteamJan 03, 2018Virtuoso
I have virtually zero experience here, but I suspect you would have to look in a different section (such as the one below).
- masonworldJan 03, 2018Apprentice
My Orbi WiFi down again -- no idea why (I mean I don't know what the root cause is). No Oreo devices here, etc. Last reboot lasted a couple of days. I am still on v2.1.1.16. For those of you that downgraded, what are you running and how is your stability?
