JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
Cotedan
Jan 05, 2018Apprentice
Everything should happen automatically. Does die mine.
orbirick
Thanks. Any idea how I can measure the difference between wired and wireless backhaul?
- cranium2kJan 06, 2018TutorTo measure bandwidth between router and satellite. Note: your measurements will be limited by the bandwidth of the laptop which is maxed out at 1Gbps of its Ethernet port.
Download iperf (https://iperf.fr/iperf-download.php) on each laptop/desktop.
Attach laptop A to a LAN port of router and run “iperf -s” which is the server piece of iperf.
Attach laptop B to a LAN port on the satellite and run “iperf -c ip-address-of-laptop-A”
See documentation of iperf for its usage- orbirickJan 06, 2018Apprentice
See documentation of iperf for its usageThanks for the iperf info. I'd come across that earlier but it appears it will take more than a casual look to get it set up and running. And out of 4 laptops in the house, I think only one can do 5 GHz. Except that I do have a Linksys A3000 dual band adapter I can use on one of the old laptops to give me dual band on 2 laptops.
This will have to wait for another day when I have time to delve into iperf and figure out how to use it. Or can I use it between my wired desktop and a wireless laptop? Does only one connection need to be wireless?
- cranium2kJan 06, 2018TutorIperf measure bandwidth between 2 end points regardless of how they’re connected.
Wireless connections of clients maybe fluctuated and can impact accuracy.
