JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
orbirick
Jan 05, 2018Apprentice
I just noticed something odd. I cranked up Wifi Analyzer and was checking my signal outdoors and happened to notice the channels. Take a look at my settings and then see what Wifi Analyzer shows. The channels I set are not being used. Or they don't appear to be. I'm sitting about 5 ft from the RBR50 when I took the Wifi Analyzer screen shots.
5 GHz radio should be on channel 482.4 GHz radio should be on channel 1Channel settings in the RBR50
- orbirickJan 06, 2018Apprentice
Following up to the above post about the band discrepancy, I cranked up Inssider on a laptop and did not see band assignment issues. The assigned bands showed up properly. I cannot reconcile the difference between WiFi analyzer on my android and Inssider on a laptop.
- st_shawJan 06, 2018Master
Your Orbi is using a 40 MHz width on 2.4 GHz. You set it to Channel 1 and it uses 1 - 5, which extends just to the edge of channel 7.
Your Orbi is using an 80 MHz width on 5 GHz. No matter what channel you set in the GUI, Orbi will always use channels 36-48.
These channels are what's shown in the plot you posted, so everything is working properly, but the way Orbi uses channels is confusing compared to the choices in the GUI.
st_shaw wrote:
orbirick wrote:Following up to the above post about the band discrepancy, I cranked up Inssider on a laptop and did not see band assignment issues. The assigned bands showed up properly. I cannot reconcile the difference between WiFi analyzer on my android and Inssider on a laptop.
Thank you for your reply. What I found confusing was apparent peaks on channel 3 and channel 42 instead of the channels I programmed. What I found confusing is that while my Wifi Analyzer app showed the channel info like that, Inssider on a laptop did NOT show those same off channel peaks. Inssider showed everything as I would expect.
I moved the 2.4 GHz channels around some after trying channels 1, 6 and 11 with Inssider and settled on channel 6 for the low band. I left the hi band alone at channel 48. And those were represented properly on Inssider. I cannot understand the multiple peaks off channel on wifi Analyzer.
