JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
orbirick
Jan 05, 2018Apprentice
I just noticed something odd. I cranked up Wifi Analyzer and was checking my signal outdoors and happened to notice the channels. Take a look at my settings and then see what Wifi Analyzer shows. The channels I set are not being used. Or they don't appear to be. I'm sitting about 5 ft from the RBR50 when I took the Wifi Analyzer screen shots.
5 GHz radio should be on channel 482.4 GHz radio should be on channel 1Channel settings in the RBR50
orbirick
Jan 06, 2018Apprentice
Following up to the above post about the band discrepancy, I cranked up Inssider on a laptop and did not see band assignment issues. The assigned bands showed up properly. I cannot reconcile the difference between WiFi analyzer on my android and Inssider on a laptop.
