lbeck02
Jun 16, 2019Guide
Orbi frequently loses Internet connection
I bought the RBK53S-100NAS system a few weeks ago to replace a Netgear WNDR3700/Amped Wireless1000 system to increase my wireless range. Also, my previous system would lose Internet OCCASIONALLY - maybe every few months. I could always get Internet back by resetting my modem and router. But since my system was maybe 6 years old, I decided to upgrade to the Orbi.
I really like the app and the Internet info provided by the Orbi, but I now lose Internet connection MUCH more frequently. Maybe several times a day and almost always when I move my android smart phone or tablet (Samsung S2) out of my network area. I'm always able to regain connectivity by rebooting the devices, but this is really annoying. I have noticed Orbi satellite 1 backhaul status is "poor" but I don't know what that means or how to correct it.
Practically all of my devices are wired to the base or one of the 2 sattellites, but my phone , laptop, and tablet are of course wireless.
Overall my experience with the Netgear system is more satisfying and I'll return the Orbi unless I can get more stable Internet connectivity. But after resetting passwords on alll my Orbi-connected devices and because I like the Orbi user interface, I'm hoping to save my Orbi installation.
What can I do to help you to help me?
Just to clarify, it is the Orbi (and everything connected to it) that loses Internet?
Or, is it the device that moved that loses internet?
- lbeck02Guide
No. The Orbi stays connected.
It's only my wireless connections that lose connections (I think). I'm still setting things up but my desktop always stays connected and it's on the primary (not satellite) orbi. My main problem is with wireless connections to my phone, notebook, and laptop. I'm also having problems with a wired AV receiver and just this evening with my smart TV (Samsung 65") but these problems may be due to botched setup. My TV is back but still working on the receiver.
- AkgqInitiateI have the same issue, I’m on the latest update. All connected devices via wire stay online. However wireless devices drop every 5-10 mins. When I checked the status. Wired connection time is up for 10 hours while wireless connection both 5g and 2.4 won’t stay up for 5 mins
- kmorimtInitiate
Having the same issue. Phone and other mainly 5g devices drop and report failure to configure IP. Everything will be fine again for 10 to 15 minutes and then stop working. Everything was working just fine for weeks after the last firmware update. I did try giving it a static Channel this am and will see what happens.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). - SBG66Aspirant
Same here. Had Orbi for only 2 weeks and getting intermitent drop outs. Everything is still connected including the router to the internet. Searched and searched and cannot find any solutions. Getting worried I've bought a dud! Any advice welcome.
SBG66 wrote:Same here. Had Orbi for only 2 weeks and getting intermitent drop outs. Everything is still connected including the router to the internet. Searched and searched and cannot find any solutions. Getting worried I've bought a dud! Any advice welcome.
- SBG66Aspirant
Ok.
Vigin superhub 3 - Modem only mode.
Orbi in Router mode
Have just disabled Daisy.
House is around 2500 sq ft. 1930s semi with thick brick walls.
Will give your other suggestions a go.
Thanks
