Roamabout's avatar
Roamabout
Luminary
Feb 27, 2018
Orbi Guest network question
I enabled the guest wifi today in anticipation of having some people over tomorrow. I changed the ssid but left it with no security. My intention was to enable it while people are here then turn it off when they have gone.
I noticed that when I enabled the guest network (this was the first time since new) it shut off all wifi for a couple of minutes and disconnected everything including both sats. The satellites and router did not reboot, just the wifi got shut off and restarted. Everything settled down, reconnected and went back to normal with the guest ssid now visible and working.
I'm wondering if that is the expected behavior and is it going to do that every time I enable and disable the guest wifi or was that a one-time thing..
  • FURRYe38's avatar
    Possible that integration of all the wireless componets that it takes a reboot and disconnect of the wireless radios to set up the Guest Network so it works through out the system. I would post this to one of the forum moderators to see what the behavior should be...DarrenM would be one to contact.
    • Roamabout's avatar
      Roamabout
      Luminary
      I did some tests early this morning before everyone was awake. Enabling and disabling the guest wifi is a slow and disruptive event, not something I want to do when a freind stops by. I opted to leave it enabled but added a password.
      • FURRYe38's avatar
        Ok, Ya, I'll give this a try with mine as well. See what happens. AFter hours LOL.
        I would contact DarrenM and give him a link to this and give him all your info. I'll post back here with anything I find.
  • FURRYe38's avatar
    I tested this out, I do see a network drop in connections with wireless devices after I selecte enable Guest Network and Broadcast SSID.
    After disabling Guest Network and broadcast SSID, I didn't see any disconnections.
    I presume maybe enabling GN seems to cause the wireless system to reboot to get the GN set up and working.
    • FURRYe38's avatar
      I got official information regarding this.
      "expected behaviour. when you enable guest SSID, we need to reset the WIFI driver and it will bring down all the SSIDs for a minute or two. This is same behaviour on all the Orbi's and I think all the OEMs as well."
        Roamabout
        Luminary
        I enabled and disabled the guest wifi a few times to observe what it did. In addition to the client disconnects it also left a satellite in a funny state during one of the restarts requiring me to reboot that sat. The symptoms were that the sat appeared connected as far as the router status was concerned but that sat and anything connected to it were not pingable from anything connected to the router or the other sat. The lesson here is that the Guest network is something that you turn on, deal with the consequences to restabilise the network, and leave on if the guest network is something you will use in the future.
