russellmoran99
Oct 01, 2017Luminary
Orbi having Problem with Cisco IP Phone SPA525G in Wireless Mode
I have an Orbi system. It has a Router, 2 satellites (RBS50s) and a wall plug in satellite (RBW30). I bought a brand new Cisco IP Phone SPA525G and have it connected wireless to my Orbi network. I...
aaz
Oct 01, 2017Virtuoso
Have you tried turning off Fast Transition?
- russellmoran99Oct 01, 2017LuminaryWhat and where is fast transition? I’m not sure it’s turned on?
- aazOct 01, 2017Virtuoso
Sorry - Fast Roaming on Advanced wireless settings - Way at the bottom of that page. You could make sure that is off.
Also I had to turn off my UPnP to have a stable Wifi network. Not sure if some of your devices are affecting that for you as well.
- russellmoran99Oct 01, 2017LuminaryThat’s funny. I actually had fast roaming turned off last week when I had the problem. I turned it on over the weekend to see what would happen. It’s the opposite advise, but I want to at least test to see if maybe the “fast” part would allow it to move quicker and not unregister from Vonage? I’m not sure about the UPnP option. I have over 47 devices attached and I am 99% sure I have configured a device particularly using that. Scares me to turn it off.
What is UPnP used for? Thanks again.
