KKE55's avatar
KKE55
Guide
Apr 30, 2018
ORBI, How many satellites does my router support?
I have a Router (RBR50) and two satellites (RBS50). I'm planning to add another satellite. Will the Router support it?
  • Retired_Member's avatar
    Retired_Member
    May 01, 2018
    yes
  • I have 4 satellites + the RBK50 router.
    Works just fine.
    Read somewhere on the forum that someone has 5 connected.
    I think the trick is when doing the initial sync, switch off all the existing satellites and make the router sync to the new satellite/s. After that has synced, switch them all on and do a reboot.
    Worked for me!
    • Aspen_za's avatar
      Aspen_za
      Tutor
      *UPDATE*
      I now have the main router and 6 satellites connected! This is a very, very expensive investment but well worth it.
      After connecting the first 3 satellites, the other 3 have to be synced one by one. Disconnect (power off) the first 3 satellites that are synced, then sync one satellite at a time with the router. This is trick. Satellite 4/5/6 have to be done with the router only and just one at a time (powering each one off after it has been synced)
      Once above steps are followed, power the entire system up, leave them to say "hello" to each other and within 5 minutes the entire system is up and running.
      Took me about 2 months to get this right so hopefully I wilk be saving someone out there a lot of time.
  • Can i connect three or more indoor satellites and two or mor outdoor satellites?
    • FURRYe38's avatar
      I think i've seen someone post that they connected 4 satellites. Not sure if using 3 indoor and 2 out door. Might be a stretch.
      DarrenM
      • tydmeter's avatar
        tydmeter
        Guide
        I have four satellites plus the router and they all work fine.
        Bill_S
  • FURRYe38's avatar
    And I responded with such info...
    Size, range and coverage does matter.
    Good Luck.
  • FURRYe38's avatar
    Seen other posters with up to 3 satellites. Depends on the size of your home as well. Larger size home may need additional. I have a 5000sq ft home, only 1 satellite needed. 40feet distance in between router and satellite.
      Retired_Member
      I believe the OP is asking whether or not the Orbi router is capable of handling an additional SAT.  Has nothing to do with size of coverage.
      • KKE55's avatar
        KKE55
        Guide
        Yeap, I am asking exactly what @VAJim said. Thanks anyway for you both.
    Retired_Member
    yes
