Doctorold
Apr 30, 2017Star
Orbi IOS app won't connect to network
I recently discovered the Orbi app after having had my network setup for some time. But the app won't connect to the wifi network I've created. I'm wondering if it's because the name of the network is no longer "Orbi Wifi". Any ideas/suggestions?
- DarrenMSr. NETGEAR Moderator
Hello Doctorold
It should not cause a issue as long as you are connected to that wifi network when using the app.
DarrenM
- gersteinInitiate
I am having the same issue. Set up the network and it is working fine but when I try to connect with the app (either the Orbi app or the the Netgear Genie app) it just times ut. Verified I am on the wifi network from the Orbi and still does not work. Suggestions?
- pwc73mgbGuide
I am having same issue. Had Orbi for a week and can't connect via phone app. Can via web. Get message network server busy, try again later. If fails constatnly, power cycle. I have power cycle numerous times and still can't get connected. NETGEAR - seems several people have this issue and you have not responded, please help. You make a big thing out of being able to manage via phone.
