walkerx
Jul 24, 2018Guide
Orbi Issues with V2.1.4.16
Hi,
I am a UK Sky fibre-pro user using the Sky Q Hub with the Orbi system. I have configured the router for AP mode and connected the WAN port to my switch and have reserved an ip address for it, m...
Jul 24, 2018Guru - Experienced User
Yes when you disable or enable anything on the router, it's recommended to reboot everything. Most settings will reboot the router. I would power cycle the satellite as well.
You have a managed switch:
https://www.zyxel.com/products_services/8-10-16-24-48-port-GbE-Smart-Managed-Switch-GS1900-Series/
There are users having problems with managed switches.
One user said to disable IGMP procotols on his managed switch and the Orbi started working correctly:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
I don't have any managed switches on my network so I can't help on this. My non managed switches all work fine though with my Orbi system.
Can you test with a non managed switch if you have one...
