Mike34848's avatar
Mike34848
Orbi loosing internet connection
Hi all,
problems with my orbi loosing internet connection. I have had this orbi for several months and it had been working super.
Now it is connected to my modem for max 30 seconds and then it loses connection every single time.
I have resetted to factory default settings and updated the firmware to 1.12.018, the very last version.
Any ideas please, or should I return the unit
regards Mike
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Mike34848
    Have you tried to enable beamforming and mumimo some people have said since the update when they enable it again seems to fix the issue.
    DarrenM
    • thedigitaltuner's avatar
      thedigitaltuner
      Same issue for me since the purchase of router and two satelittes.  Completely losing the internet on latest firmware verison.  Really frustrating as when traveling I lose acessess to my cameras and the thermostats.  Can't believe how expensive for how bad.  When i get home I am going to have to go back to my old router.  The orbi even after updates has the same problem of losing connection even when no one is home using it, falls over and does not recover.  Really big issue and no solution.
    • Mike34848's avatar
      Mike34848
      Hi DarrenM,
      thanks for your ideas. I have been away a few days, but I will try enabling beamforming and mumimo. I first have to find out how to do that...
      And I will try the factory default reset first, have not done that after the firmware update.
      mike
  • DarrenM's avatar
    DarrenM
    Hello thedigitaltuner
    Have you done a factory reset since being on the latest firmware?
    DarrenM
