lostwhirley's avatar
lostwhirley
ORBI MESH RBK23 drops WLAN a/n/ac consistently
I'm noticiing that my TXPkts drops down to zero consistantly. I'd say at least once every 30 seconds, the Transmitting packet shows that it drops to 0. Comes back up immediately, then drops to zero ~20-30 seconds later.
No collisions. All other WLAN works great.
Help?
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    • lostwhirley's avatar
      lostwhirley
      Firmware :  -- 2.3.5.30
      -- Netgear Model c3000
      -- Router
      3 levels (including basement). Around 2800 Sq. Ft.
      • FURRYe38's avatar
        Your modem has a built in router and wifi already. Is the modem bridged? It can be and is recommended to be bridged if your going to use a Orbi system with it.
