Smilingsallyjun's avatar
Mar 26, 2020
Orbi mesh spectrum problem
Spectrum had to update and reboot my system. My orbi will not reconnect.  I have gone through all the steps numerous times. It does not even recognize that it is plugged into modem.  I have never had trouble before.
  • FURRYe38's avatar
    Power OFF both ISP modem and RBR for 30 seconds, then back ON with the ISP modem first, then the RBR.
  • Retired_Member's avatar
    Retired_Member
    what type of spectrum gear are you running?
    have you tried to simply reboot your entire network?
  • Had the same problem. Did everything i could think of to clear not obtaining a DHCP served ip address from the WAN. I even rest back to factory defaults.
    Worked with spectrum. They flushed the mac from their cache and everything else.
    Direct connect from my computer worked.
    Switch back to my old crappy router and it worked......
    Returned my Orbi . Really bummed cause it worked great for 12 hours.
    • FURRYe38's avatar
