JD1911
Sep 15, 2020Aspirant
Orbi Mesh System Compatibility with Arris
I am looking at getting an Orbi system for my house. I have an Arris TG1672-NA WifI modem/router currently. The TG1672 combines two analog voice lines, a 4-port Gigabit Router, and 802.11n wireless a...
Sep 15, 2020Guru - Experienced User
They all should be compatible.
To avoid a double nat, you could put the arris in bridge mode.
or the orbi setups in access point mode.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
or you could put the orbi's ip address in the arris's dmz. (a little more challenging)
JD1911
Sep 17, 2020Aspirant
Thank you for the information. This is very helpful.
