ZanL's avatar
ZanL
Tutor
Jan 26, 2021
Orbi Mesh Triband won't connect to my HP Officejet 8740
Can anyone help me to get my HP printer to connect to my Orbi?  I just spent 2 hours on Netgear tech support.... They could not fix my problem.  I changed the 2.4 ghz channel to 11.  Nothing...   I was told to go to the advanced tab for the router and on the WAN setup, open the NAT filtering... I did and nothing.  I am good with computers, but not experience with network problems.
  • I just armwrestled with my HP Envy printer. One of the steps in curing the problem was to delete the network information from the printer, shut it down and unplug it for 30 seconds or so. (If you pray, it can't hurt to do this during the wait. No, I don't have a good prayer for a printer. 🥸) Plug it back in and start all over.
    Amid the sophistification of this forum, please forgive these simple recommendations.
    The printer connects to the orbi not the other way around
    how far is the printer from the orbi router?
    does the printer have a network setup built in?
    • vajim's avatar
      vajim
      Master
    • ZanL's avatar
      ZanL
      Tutor
      They are right next to each other.  the printer does have network setup.  It was working fine with my old router setup.
      • vajim's avatar
        vajim
        Master
        so how did you set it up with the old router?
        wifi is wifi....except in the case of a Mesh network.  Maybe your printer can't handle having both freqs in one SSID
  • FURRYe38's avatar
    Contact the printers Mfr for additional help and infromation regarding there product.
    • CrimpOn's avatar
      CrimpOn
      This is very good advice. I prefer singing Happy Birthday and saying, "There's a good WiFi device. Be nice now."
      Being superstitious, I always assign an IP address to printers so that they are always in the "same place".
    • ZanL's avatar
      ZanL
      Tutor
      After working on this for over 2 hours the day before.. I deleted the printer from my computer.  Removed the network from the printer.  Unplugged the printer...  Reinstalled the printer, took a deep breath, and had a cocktail.  Plugged the printer back in,   and then reconnected the network.  Its on!!!
      • vajim's avatar
        vajim
        Master
        nice work....please mark this thread as solved.
