AnnieBelle
Jun 17, 2020Follower
Orbi Model RBK50 When syncing the satellite does the light pulse on stay on steady when synced?
I am having a hard time connecting my robot vac to the internet. and I am wondering if the satellite orbi is synced with the main router. I get a blue color but it is pulsing and not staying on steady. What am I doing wrong. Our tvs are connected ok.
AnnieBelle wrote:I am having a hard time connecting my robot vac to the internet. and I am wondering if the satellite orbi is synced with the main router. I get a blue color but it is pulsing and not staying on steady. What am I doing wrong. Our tvs are connected ok.
Here are what the colors mean: https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean . It says:
Pulsing blue and magenta. The Internet connection is blocked because the traffic meter is configured to block Internet traffic when it reaches the limit you configured.
Do you have any traffic limits set on your Orbi?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
