Dumbus
Jan 20, 2021Aspirant
Orbi Network Apple Devices
Last week on Tuesday or Wednesday Hotmail login and Active directory login started being blocked on Apple Devices using the Orbi wifi network. It previously worked fine and still works fine if I do not use the mobile or other wifi networks. Has anyone else encountered this issue? Basically the Apple device on the Orbi wifi asks me to renter the password for the Hotmail account. The Microsoft online website to confirm the password is not available.
Dumbus wrote:I tried everything. Put Telstra Modem in bridge mode etc. Finally I found in the Orbi admin website (not on the Orbi App) that Disney Circle was enabled under the security tab. Turned it off and everything works again. Now I just need to find out why the Disney Circle App was blocking Microsoft websites suddenly. Thanks for your help
Nice
you may want to mark your post here as solved.
thank you
Orbi doesn't block anything unless you have either Armor or maybe Circle apps enabled.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- DumbusAspirantFirmware is 2.5.2.4. It is connected to Telstra NBN via a Telstra Smart Modem v2. I tried turning off Armor security and still had the problem connecting to Hotmail and Active Directory. I do not think circle is active but not sure as I do have the app.
What mode is your modem working in? Modem or router? This modem has a built in router already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
