Aviw
Jun 16, 2020Aspirant
ORBI never worked, lower the speed from 300 to 13!!!
Any idea how to make it work, or just go back to the grate Linksys?
Is this speed test via wireless speed or wired? Wire speeds are preferred.What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
- AviwAspirant
What Firmware version is currently loaded? Version V2.3.5.30
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Optimum ARRIS TM-1602
Is this speed test via wireless speed or wired? Wired!I did not change any settings, this is how it works out-of-the-box (or actually dose not work)
Do you enable Armor or Cicle by chance?
You might update to v16 on the RBS first then RBR lastly:
then factory reset and setup from scratch. Power OFF the ISP Modem for 30 seconds then back on. Be sure to not enable Access Controls, Armor, Circle, QoS or Traffic Meter. Speed Test with a wired connection soon as the setup wizard is completed with Ooklas installable speed test app. Test with a 2nd PC to be sure. Ensure the network adapter is getting 1000Mbps connection rates on the adapter.
