insomniaNL's avatar
insomniaNL
Orbi not connecting to internet
Hi guys, I have a problem connecting to internet with my new Orbi set. Setting up wifi was a breeze, I can acces the admin on the Orbi using WiFi, but getting internet access seems not possible. I use a Huawei DSL router model HG659 (Vodafone internet, Netherlands). I have disabled the WiFi on the Huawei router, but the Orbi will not connect automatically to internet.
I think I should use AP mode (instead of router since I already have one) on the Orbi and I tried this setting too, but no luck: if I select this mode, I can no longer connect to the Orbi through WiFi. After using a pin to push the reset button I can access the Orbi again, and have to start over. Frustrating!!! Any tips for a struggling home owner?
    • yes the orbi will switch ip subnets if its see's an ip conflict during setup
  • hi
    the first thing to try is another ethernet lead between any of the lan ports in your  dsl modem and the orbi yellow wan port
    also make sure there are no mac address filtering and or firewall rules set on the dsl modem that would block the orbi
    • insomniaNL's avatar
      insomniaNL
      Hi Petey, good idea: I swapped the cable for a new one, also changed the ports, but no luck... There is no mac address filtering or firewall rules that would block the orbi. I can see it gets assigned a valid IP address, but still no internet...
      Anybody with some more tips? thanks.
      • peteytesting's avatar
        peteytesting
        Hero
        check to see if the adapter you are using hasnt got a static ip set on it and its set to obtain dhcp and dns automatically
        how are you seeing it gets a valid ip address ? is that on the dhcp server of the modem or on the orbi its self
