Pistol1957's avatar
Pistol1957
Follower
Nov 14, 2016
Orbi Placement
Is is okay to place the Orbi & modem in an enclosed cabinet or closet?
    its prob best not to as you may effect coverage and connectivity
    • TomMac's avatar
      TomMac
      Guru
      Any time you add more walls / materials between the main unit and the sat, you'll be cutting down on signal..
      That said...in my case a stick built home.... my sat is 40 ft away from the main and it did end up in a closet on a self ( wife didn't want it on her work desk ( happy wife, happy life ))
      Tests before and after showed no diiference with  transfer rates as I could tell.
  • Agree with the previous posts about adding more walls/doors just degrades signal ....
    ... but I too also have the base router in a pantry in the garage and have noticed no degradation in signal either.
