fruitypigy
Feb 12, 2017Guide
Orbi Portforwarding not Working
I reccently got a new orbi router and have been having issues with portforwarding. I just tried making a minecraft server and everything is fine but something with the port forwarding is wrong. I used 25565 and did UDP and TCP and my local ip. However my friends cant connect and when I go to a port tester it says that 25565 is closed on my ip.
Has any one else had this issue and does anyone know how to fix it?
- DarrenMSr. NETGEAR Moderator
Hello Fruitpigy
Are you using a mode/router combo unit as your modem?
DarrenM
This is a dup of https://community.netgear.com/t5/Orbi/Orbi-Portforwarding-Not-Working/m-p/1231339#M4433 and there are more questions there for the OP.
