DCP4971's avatar
DCP4971
Luminary
May 25, 2021
Orbi Power Cycling
Hi all,
We've been having a few ISP issues of late and wondering if this might be causing our Orbi to power cycle. It's running in Router mode, connected to our ISP provided router, It seems to randomly restart every now and again, including this morning (when my wife had started work, so was quite disruptive).
I've been doing some digging and managed to find the UpAgent.log file which shows when the connection drops. I can then see the auto_fw_upgrade_log file which shows an entry 'AUTO FW CHECK: power cycle', at the time that it all went down.
Anyone know if this power cycle can be caused when the internet connection drops, or what else might be triggering it?
I'm on FW 2.7.2.104.
Thanks,
DCP
  • CrimpOn's avatar
    CrimpOn
    DCP4971 wrote:
    Hi all,
    As far as I am aware, only a loss of power or deliberate act by the user will cause the Orbi to power cycle.
    Does the regular Orbi log show the system restarting?
    The message should be something like this:
    [Initialized, firmware version: V2.7.2.106] Tuesday, April 20, 2021 23:13:16
    Does the regular Orbi log show internet connecting or disconnecting?
    [Internet connected] IP address: 172.249.112.236, Tuesday, April 20, 2021 23:13:17
    [Internet disconnected] Sunday, April 25, 2021 14:16:29
    (These dates are not significant.  I email every Orbi log to myself and create an Excel file for each month. To find these entries, I sorted the entire file to find what the log messages look like.  It appears the last time I restarted my Orbi was April 20.
    • alokeprasad's avatar
      alokeprasad
      Mentor
      Flaky power supply?
      Hardware problems in the units itself (bad RAM), causing spontaneous reboot?
      These things are small computers .. so thinking of random restarts causes of PC's ....
  • FURRYe38's avatar
    If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Has a factory reset and setup from scratch been performed since last update?
    DCP4971 wrote:
    Hi all,
    Thanks,
    DCP
