Dp1999's avatar
Dp1999
Orbi RB50 multiple SSID visible
I have one computer connected via LAN to the orbi router. This connection shows SSID Orbi66 2. The other devices (but also this computer) have wireless connections to the router/satellite. This connection shows SSID Orbi66. The fact I see 2 different SSID's came after a problem with the wireless internet connection and the need to reboot the satellite. How can I eliminate the different SSID?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    I would try to first power cycle all the orbi units see if that works.
    DarrenM
    • Dp1999's avatar
      Dp1999
      If you mean switching on and off all devices than this does not work.
      • guzzijason's avatar
        guzzijason
        Apprentice
        If you haven't yet, I would try re-syncing the satellite to the router.
