HoangNa297's avatar
HoangNa297
Orbi RBK 50 AC3000
I'm just Update new version newest form orbi app ( V2.1.4.10) is problem,it's drop my connection .. i want to get back old firmware ...any help me downgrade ??? thanks..sorry my bad english :( !
  • DarrenM's avatar
    DarrenM
    May 10, 2018
    You could try a factory reset it has had good results for others after upgrading to this firmware.
    DarenM
  • FURRYe38's avatar
    Has a system reboot or a full factory reset then set up from scratch been performed?
    • HoangNa297's avatar
      HoangNa297
      It’s only auto reboot when update finish,i’m don’t hard reset it,i’t seem this firmware not stable
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Is all of your orbi units upgraded to the 2.1.4?
        DarrenM
