Koceto
Feb 10, 2019Aspirant
Orbi RBK 50 AC3000
Hello All.
Could somebody tell me if Orbi RBK 50 AC3000 is automatically switching devices connected at 2.4GHZ network to 5GHZ. I have designated devices which are working only at 2.4GHz and this kind of switching will keep disconnecting them from the network. I know that the router has only 1 SSID and I cant separate both bands which has worried me little.
- ekhalilMaster
Orbi uses "Band Steering" to try to move capable devices from the 2.4 to the 5 GHz bands. When devices attach to Orbi devices send their capabilities to Orbi so Orbi will know if those devices can or can't be moved between the bands.
If your 2.4 GHz devices are being disconnected then this might be because of other reasons:
- What type of devices are experiencing disconnections?
- Do you notice that devices are being disconnected when roaming between the Orbi nodes?
- What is the distance between the router and satellite(s)?
As ekhalil pointed out, a device that can only communicate at 2.4G will tell that to the Orbi. the Orbi will never "see a signal" from that device on 5G, and thus will never attempt to "steer" the device to 5G. The Orbi cannot detect that the device "would be better on 5G", so the question is moot. It can't happen.
From the question, is it difficult to ascertain whether (a) there are devices which are mysteriously dropping their WiFi connection and you are looking for the cause, or (b) you are about to install a new device that operates only on 2.4G and you are concerned about the vendor admonition, "MUST be connected to 2.4G WiFi".
Specifics of the situation is key.
- KocetoAspirantThanks for the answer CrimpOn. You are correct. I am planning to get Orbi and I was worried about my Electrical Heaters Adax which are only working on 2.4 GHz. So I can go ahead and take Orbi system and know that Orbi will never try to switch them on 5 GHz. Just precautions. Also do you know how much devices I can connect at once on this system because I am planning to build smart home and to use Orbi RBK 50 AC3000 as a Mesh system. If this model is not good for this job which are you going to recommend?
Conditions of WiFi also include environment and other neghboring WiFi stations. Congestion conditions will be more problematic when having lots of other wifi neighbors near by like in condo or apartment dewellings.
Configuring manual channels vs auto can help this.
Also lowering the power output levels from the Orbi can help this aswell.
Koceto wrote:
Hello All.
Could somebody tell me if Orbi RBK 50 AC3000 is automatically switching devices connected at 2.4GHZ network to 5GHZ. I have designated devices which are working only at 2.4GHz and this kind of switching will keep disconnecting them from the network. I know that the router has only 1 SSID and I cant separate both bands which has worried me little. - FURRYe38Guru - Experienced User
What is the size of your home? Sq Ft? This will ba a factor to consider when setting up a Orbi system. You may need more than just 1 satellite.
Distance between the router and satellite(s) is key as well. 30 feet is recommended in between them to begin with depending upon building materials.- KocetoAspirantHi,
My flat is around 1800sq ft and I have 4 rooms all in 1 line. So I am planning the router to be in the room at the edge and then the satellite in the middle room . Distance in between will not be more than 15-20 feet. Walls are also regular bricks and not anything special. That's why I think that 1 Router RBR 50 and one satellite will do the job. - KocetoAspirantHi,
My flat is around 1800sq feet and I have 4 rooms in total aligned some how in a line. I am planning to place the RBR 50 in one of the rooms at the end and then the satellite in the middle room no more than 15-20 feet away. That's why I think that this configuration will work. Walls are just regular bricks and nothing special.- Chuck_MMentor
The RBK50 kit... which includes 1 RBR50 router and 1 RBS50 satellite will work perfectly for your scenario. It is precisely the same I originally installed.
I have since added two additional satellites to reach some distant parts of the property.
Two of my RBS50's are hardwired via ethernet cable back to the RBR50. The third satellite uses wireless backhaul.
I do have a netgear switch in there somewhere to give me additional wired devices.
I have at any moment well over 50 devices active.
This includes
A very large sonos constellation -- including
.Play 1s (about 10)
.Play 3s (4)
.Play Bar
.Sonos Boost
.Sonos Amp
Nest doorbell
Nest smoke detector
Nest thermostat
Hue lights
About 7 Samsung TVs
4 x computers
1 x Pentair Pool controller
Roomba
1 WD Mycloud Mirror NAS
Bluerays (multiple)
Petcube
Samsung security system w/16 cameras
Alarm system
Rachio irrigation system
Chamberlain garage door openers
Ipads (my wife!)
Iphone (my wife!)
Androids
Alexa Show
Alexa Dots (5 or more)
Alexa Echos
Works like a champ at max speed.
