JJSnels's avatar
JJSnels
orbi rbk 53 ip adress, how to change
Hi, I notice I can not change the ip address of my Orbi 53 (only app?!?). I am connected to a Zyxel T-50 modem. They both have the same ip-address and that gives problems with a lot of websites.
Thanks.
  • FURRYe38's avatar
    What mode is your ISP modem working in? I believe it has a built in router already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Any IP address changes need to be effected using a web browser connected to the RBRs web managmenet page at orbilogin.com
    • JJSnels's avatar
      JJSnels
      Thanks for your prompt reply. I will discuss the possibilities with my ISP.
      The model is: VMG8825-T50
      • FURRYe38's avatar
        For now you could disable the wifi radios on the modem and configure the Orbi for AP mode.
  • CrimpOn's avatar
    CrimpOn
    Can you please report the entire product model number?  When I search for "Zyxel T-50", it appears that there are a number of Zyxel products which end in T-50.
