Conny999's avatar
Conny999
Orbi rbk20
Today my internet connection went down frequently. Not the first time and a friend with same Orbi router experience the same problems at the same time. Anyone with a solution or explanation to this?
  • FURRYe38's avatar
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • Conny999's avatar
      Conny999
      Latest version.27, size of home doesn’t matter since the router is the problem. Switched back to my old router and instantly all problems were gone. This happens once a month (approximately) - as I said, a friend with the same equipment with a diffrerent provider has the same problems at the same time (once a month)
    • Conny999's avatar
      Conny999
      Didn’t mention, last month I did a total reset, even the staellite worked for a week. Now it’s back. Exactly the same scenario at my friends house
      • FURRYe38's avatar
        I would contact NG support for further help and information. Ask about an RMA.
        Good Luck.
