Morikid's avatar
Morikid
Orbi RBK23
Just a general question, whether the RBK23 suitable for a 500mbps incoming service, or will the RBK50 would be better, its a medium size house with a garden room.
Thanks
  • CrimpOn's avatar
    CrimpOn
    They are different products.
    • The RBK50 has one router and one satellite.  The RBK23 has one router and two satellites.  In a medium size house, this may not make a significant difference.
    • The RBR50 (router in the RBK50) has three ethernet LAN ports. The RBR20 (router in the RBK23) has one ethernet LAN port.
      This is not a significant difference because that port can be connected to a cheap gigabit switch to allow many devices to be connected.
    • The RBK50 has separate radios and antennas for the 5G WiFi backhaul channel, which produces a theoretical maximum backhaul rate of 1.3GB.  The RBK23 uses the client radios and antennas for 5G WiFi backhaul and has a theoretical maximum backhaul rate of 833mbs, which is shared with client devices.  If the router and satellite(s) were connected using ethernet cables for backhaul, there would be no significant difference.
    I doubt most users would  notice a difference between these products unless they intend to connect a very heavy usage device to the satellite over 5G WiFi and expect to backhaul that traffic over the WiFi link to the router.  There is no chance that such an application will realize 500mbs of actual usage in that scenario.  I don't think the RBK50 would either, but it would do more.
    Sorry not to be more help.
    • Morikid's avatar
      Morikid
      Thank you for the insight of the product & capability. I am UK VIRGIN MEDIA services on a 500mbps service. Their hub is a smart hub 3, but in my opinion & research that hub has poor wifi ping as soon as you move out of the Room the router is in. Thought that the RBK50 would be ideal but costly !! That why I was looking at the cheaper RBK23.. if that make sense 👍🏼😊
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem you currently have?
    Thanks
    • Morikid's avatar
      Morikid
      Virgin Media Smart hub3, at the router using my iphone 10, I get about 400-530mbps on wifi. Brilliant, but everywhere else in the house it ranges from 30-80mbps. Having read about the capability of the Orbi 23, thought that might improve my home wifi generally. As my service is 500mbps, the RBK23 is rated ideal for 200mbps.. thats means although i have 500 at my router, if using RBK23 I would be limited to a 200mbps !! Not sure
