mdax's avatar
mdax
Follower
Jan 04, 2018
Orbi RBK30 in AP mode
Do I set the SSID in the Orbi under AP mode to the same as the original router or should I use a different SSID for the Orbi? Tks.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Best setup is disable the wifi on the main router and just use the Orbis wifi network.
    DarrenM
